particleIllusion for Mac updates released
COW Forums : Particle Illusion
Alan Lorence
on Nov 25, 2008 at 1:13:16 am
There are new versions of the following apps now available:
- particleIllusion 3.0 for Mac (3.0.8)
- pIllusionRender for Mac (3.0.3)
- particleIllusion SE for Mac (2.0.3)
Use the AutoUpdate ("check for updates") feature if you're running a recent version that has it, otherwise get the appropriate update installer from our website:
http://www.wondertouch.com/default.asp?loadContent=updates.asp
You can see a list of the pI3 3.0.8 changes (tons of bug fixes) here:
http://www.wondertouch.com/downloads/updates/pI3_OSX_308_Release_Notes.html
It is *strongly* recommended that you update.
Alan.
Alan Lorence
Re: particleIllusion for Mac updates released
on Nov 25, 2008 at 5:56:41 pm
Also, if you're using pI3 with OS X 10.5, you'll need the particleIllusion QuickLook plugin in order to get the previews of project and emitter library files in particleIllusion (and also in Finder).
Only needed if you are running pI3 (not SE) on 10.5. Not needed on earlier OS X versions and won't install on them anyway.
http://www.wondertouch.com/downloads/pIllusion3_QL_Installer.pkg.zip
Alan.
