alpha
COW Forums : Particle Illusion
Les Stella
alpha
on Nov 11, 2008 at 1:34:47 pm
In the help section it says using Uncompressed AVIs are not recmmended. However, I can't seem to find recommended Huffy UV or Lagarith under the avi save as choices. Am I doing something wrong?
Craig Cooper
Re: alpha
on Nov 18, 2008 at 4:35:47 am
These codecs have to be downloaded and are free. Once you have downloaded them simple right click on the file and select install. Windows will then install them to the correct location. The next time you want to render you will see them there.
I hope this helps.
Craig
Cheers Craig
Peace Talks Hamper War in Middle East
Les Stella
Re: alpha
on Nov 18, 2008 at 7:40:19 pm
Craig,
Thanks for the help. It is truly appreciated. You seem to be knowledgeable in this area. Where do I go to download those two codecs? Thanks for your time. If it's easier for you, you can send them straight to me via email.
Les.stella@gmail.com
Alan Lorence
Re: alpha
on Nov 18, 2008 at 7:45:47 pm
Search using your favorite webseach site "Lagarith codec". Also "huffyuv codec".
Alan.
http://www.wondertouch.com
