flying paper column
COW Forums : Particle Illusion
anthony blinco
flying paper column
on Nov 5, 2008 at 4:47:37 am
does anybody know if there is a particle emitter that would simulate a column of paper flying around. i would like to control the direction of the paper as well
thanks in advance for any help
Alan Lorence
Re: flying paper column
on Nov 5, 2008 at 1:32:08 pm
I don't know what you mean by "flying paper column".
Alan.
http://www.wondertouch.com
anthony blinco
on Nov 5, 2008 at 8:43:40 pm
like this. the paper flies out of the box and moves around in a column. like a snake. does that make sense? i figure it's gotta be a fountain type of movement seeing as all the paper starts in the box.
anthony blinco
on Nov 10, 2008 at 8:03:21 am
any ideas? i've been racking my brain trying things but i just can't seem to get the effect AND the control i want.
Alan Lorence
on Nov 10, 2008 at 4:02:35 pm
The key here is in the image sequence you'll use for the paper. You can't just load a single image of paper -- it will have to be animated in some way to provide some complex motion.
Take a look at some of the "feather" emitters in particleIllusion (search using particleView) for an example of what I mean.
You could also take a look at the "confetti" emitters (again search with particleView).
Alan.
anthony blinco
on Nov 17, 2008 at 10:38:56 pm
sorry to take so long to get back to this thread.
thank you so much for this.
it has helped me out a lot!
