License Tranfers Question
COW Forums : Particle Illusion
Leonard Rivera
on Sep 21, 2008 at 8:08:37 pm
I want to move PI from my C drive to my D drive on the same computer. What's the best way to do this?
I've had several issues over the past few months that required me to uninstall and reinstall PI several times, I'm not sure what that means as far as the state of my activations. (Hdds crapping out and OS reinstallations due to bad PSU)
Alan Lorence
Re: License Tranfers Question
on Sep 22, 2008 at 9:13:54 pm
I'd suggest uninstalling, then reinstalling. If it's already activated on this machine, you probably won't need to activate again since you haven't changed hardware.
Don't forget to backup any emitter libraries you've modified or created before uninstalling.
If you do need to activate again and are out of activations, email info at wondertouch dot com.
Alan.
http://www.wondertouch.com
Leonard Rivera
on Sep 22, 2008 at 9:23:54 pm
Thanks... I've got it all backed up...I'll give it a go shortly...
Leonard Rivera
on Sep 24, 2008 at 12:17:38 am
Worked like a charm. I just copied the PI directory to where I wanted to install it (from C: to D:) then uninstalled it from C and reinstalled it to the copied DIR, worked great - didn't ask for activation.. Thanks..again.
