3.0.7 OSX installation problem
COW Forums : Particle Illusion
Nigel Wainwright
on Sep 5, 2008 at 3:22:30 pm
When I run the installation package for 3.0.7 the installation jumps from the 'License' stage to the 'Check Location' stage, missing out the 'Destination Select' option. It then tells me I have chosen to install the software at the following path: Label, and to click 'Go Back'. When I do this, it takes me to the 'License' stage and the whole process repeats itself. I cannot get to the 'Destination Select' option.
Any ideas?
Alan Lorence
Re: 3.0.7 OSX installation problem
on Sep 5, 2008 at 3:46:48 pm
Just to be clear, this is the 3.0.7 update installer, not the full version installer (only the update does a "check location").
What OS X version are you running?
Alan.
http://www.wondertouch.com
Alan Lorence
on Sep 5, 2008 at 10:20:42 pm
There is a manual update you can do instead:
http://www.wondertouch.com/downloads/updates/pIllusion_OSX_307_update_no_in...
There is no installer -- just unzip the files into your particleIllusion 3 application folder, replacing the existing files. Don't drag the entire folder -- select and drag all of the files and folders that are in the folder to your particleIllusion 3.0 folder. (does that make sense?)
Alan.
NIgel Wainwright
on Sep 7, 2008 at 6:15:38 am
Hi Alan,
Thanks for the manual update which I could not find on the website. However, the website does offer the following download for the 3.0.7 update:
pIllusion_OSX_307_update.pkg.zip with the instructions, 'unzip, the double-click the pkg file to start the installer'.
This is exactly what I did - I am using OSX 10.5.4.
Regards,
Nigel
Alan Lorence
on Sep 8, 2008 at 5:17:20 pm
There's a new update installer on our site now that doesn't have this problem:
http://www.wondertouch.com/downloads/updates/pIllusion_OSX_307_update_a.pkg...
Notice the "_a" in the filename.
This one will let you choose the destination -- If you haven't done the manual install yet, please give this new installer a try.
Alan.
