Export effects to flash
COW Forums : Particle Illusion
David Vallejo
on Jul 31, 2008 at 7:57:10 pm
Hi! my name is david. i´m a graphic design student.
i need help with particle illusion at the time i want to export effects to flash.
When i export a .png sequence of images to import in flash and convert it into a movie clip, the size that i exported, appears different at the time it is in flash. Why?
A solution that i find is to scale the movieclip in flash, but still i think it´s not the best way to do it.
If someone could recommend me the best way to do it, even if it would be better to export as another format rather than .png to use it later in flash.
thanks in advance!
Alan Lorence
Re: Export effects to flash
on Jul 31, 2008 at 8:44:40 pm
I could have sworn I just answered this via email or here in the forum, but I can't find it.
Make sure you're using the latest verion. Older versions wrote bad info in the header of PNG files, and if you use an application that uses the header info (it was DPI or pixel aspect ratio) the image will import wrong.
Also, try using TGA or JPG if possible.
© 2018 All Rights Reserved
