Vista / 64 bit issues?
COW Forums : Particle Illusion
Donovan Werts
on Jul 19, 2008 at 12:01:07 am
Hi, I want to buy a new computer. It will have Vista and a 64 bit system (not sure what that means exactly) and I was told that some software might not work with 64 bit systems. Does Particle Illusion have issues? I already use, and love, the software. Not wanting to get a computer that it won't be compatible with. Thanks In Advance, Donovan
Leonard rivera
Re: Vista / 64 bit issues?
on Aug 2, 2008 at 4:08:34 pm
Well, I just setup my Vista 64 bit and particle illusion does not seem to work at all. I even try running it in Windows XP compt. mode with the same results. I sent an email to Alan inthe hopes that this can be addressed.
Alan Lorence
on Aug 2, 2008 at 6:36:02 pm
I did not receive the email (yet). You must be running 3.0.2 or later.
http://www.wondertouch.com/default.asp?loadContent=updates.asp
Alan.
leonard rivera
on Aug 2, 2008 at 9:32:37 pm
Thanks ALAN! Worked like a charm. Not sure why you did get my email. Doesn't matter now, you fixed right fast. Thanks agan, all the best.
Lenny
Leonard Rivera
on Aug 3, 2008 at 7:15:08 pm
BTW - I did get undeliverable finally - I sent it to alan@egz.com
This message was created automatically by mail delivery software.
A message that you sent has not yet been delivered to one or more of
its recipients after 27 hours.
The message has not yet been delivered to the following addresses:
host egz.com[216.8.179.23]:
connection to mail exchanger failed with timeout
Alan Lorence
on Aug 14, 2008 at 7:58:04 pm
Did you have to do anything special to get 3.0.3 working on Vista 64? Is there some compatibility setting (or whatever) that is required?
Alan.
