Preview not working?
COW Forums : Particle Illusion
Nate Whited
on Jul 15, 2008 at 9:15:55 pm
Only about half of the emitters will play in my preview window. Is this normal or am I missing a setting somewhere?
Alan Lorence
Re: Preview not working?
on Jul 15, 2008 at 9:30:57 pm
Open the Project Settings dialog and look at the framerate. If it's not 30.00, some emitters may not show and you'll need to tweak the "number" property for these. There are typically just a few emitters in any one library (at most) that do this though -- most are not very sensitive to different framerates.
1/2 not working? Very unusual.
Alan.
http://www.wondertouch.com
Nate Whited
on Jul 15, 2008 at 9:43:52 pm
It is set at 30.00. In the June emitters, only 1 of the six "regular" emitters plays in my preview window. Maybe I need to load the software?
Alan Lorence
on Jul 15, 2008 at 10:09:59 pm
Make sure you're using the latest version (3.0.3 on Windows), 3.0.6 on Mac.
Alan.
Nate Whited
on Jul 16, 2008 at 2:08:43 pm
I am running 3.0.5.
Today I went to open the software and I get nothing. Just a blank screen. As soon as I try to start something it crashes. I tried to load the software but with the same result.
Alan Lorence
on Jul 16, 2008 at 2:25:32 pm
Not sure what you mean by "blank screen", but try deleting your preferences file. It's:
/ Library / Prefrences / pIllusion3.prefs
After you delete that file pI3 should work fine.
Alan.
