Targa or PNG...which is the best..
COW Forums : Particle Illusion
Steve Rhoden
on Jun 23, 2008 at 11:43:34 pm
Which is the best image sequence with alpha channel to render out to,
in terms of pristine quality...Targa or PNG ?
Alan Lorence
Re: Targa or PNG...which is the best..
on Jun 24, 2008 at 12:29:57 am
Both are identical. They both are lossless formats, so you have no loss in image quality.
TGA can use compression, and PNG uses compression, but they both use lossless compression (like a ZIP file).
I personally use PNG more than TGA because it typically results in smaller image sizes, but I use TGA too.
Alan.
http://www.wondertouch.com
