Help with video playback
COW Forums : Particle Illusion
Ty Emery
on Jun 20, 2008 at 6:02:48 am
Hi there, particle illusion is great and I really wan to start using it on my video projects however there is a small confusing problem. I import the regular speed video into particle illusion but it plays back at almost half speed, as if it's slow motion or something. Does anyone have an idea of what could be happening here? Thank you!
Elvis Deane
Re: Help with video playback
on Jun 21, 2008 at 2:14:03 pm
One possibility is that it's not playing back at full speed because the clip is just really big and your system can't play it back with all the particles at full speed. Does it play half speed once you render the project out, or only when played back in particleIllusion?
It could also be a difference between the frame rate of your original clip and your project in particleIllusion. Double-check in the project settings that they are the same, though you should be given a warning when you are importing the video about a difference.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
© 2018 All Rights Reserved
