Rendering a good quality...
COW Forums : Particle Illusion
Dylan Lao
on Jun 20, 2008 at 2:34:57 am
I just like to ask how can I render or get an good quality animation result? I tried to render my work, then I import it to the Flash using the "High Quality (700kbps) Encoding", then the result of the quality of my animation is not good. What should I do in order to get the good quality animation? Please Help...
Elvis Deane
Re: Rendering a good quality...
on Jun 21, 2008 at 2:18:41 pm
Your best bets for going out to Flash are to render an AVI using an uncompressed codec like Huffy or Lagarith, or to render out a sequence of PNG files, which you can bring into Flash as a clip.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
Dylan Lao
on Jun 21, 2008 at 3:33:42 pm
I'm so sorry but I really don't have an idea about this because I'm still new in particle illusion. But if it is ok with you, Can you give me a proper procedure in importing a video from particle illusion to flash? specially using the huffy and Lagarith.
