drawing moving pencil sketch matte..
COW Forums : Particle Illusion
romy marx
on Jun 8, 2008 at 9:37:58 pm
hi
i have job where i want to do matte of drawing pencil sketch with pencil sound effect..
i don't have this matte ready done..
so i have idea to use record position tool at PI by drawing any motion for emitter..
but the problem.. can anyone tell me which library i can use to get solid white ink emitter to record its drawing motion???how can i do this..
best regards
Romy
Alan Lorence
Re: drawing moving pencil sketch matte..
on Jun 9, 2008 at 1:14:30 pm
There's no existing emitter for this, but you can modify an existing one easily.
Load the "follow me 2" emitter from the "trailers_01" library (also in "alan_00_06" if you have that instead). Put that emitter on the stage, then open its properties dialog.
Click the "particles" tab, then the "colors" tab
R-click in the color gradient and "reset"
Select the first (only) color point in the gradient which is now black, then make it white.
Then you can make some other adjustments -- maybe set "size variation" to 0, uncheck "intense", increase the "number" of particles, etc.
Increase "life" if you need the particles to live longer.
Alan.
http://www.wondertouch.com
Martin Starke
on Jun 10, 2008 at 8:15:51 am
Hello Frends,
I had already an idea for such a thing. I wanted the laser-emitter to use to write. Would be beautiful to write thereby but I did not try out however yet.
Martin
