Searching a way for importing position data from voodoo or icarus ...
COW Forums : Particle Illusion
Dennis Fassbaender
on May 22, 2008 at 9:04:30 am
Hi!
At ths time im using Voodoo and Icarus for tracking my footage and it works very, very well.
But i donĀ“t know, how i can import that position data into particle illusion.
I whanted to try importing LWS-Date to cinema 4d and than use the ParticleIllusionExporter- but there is no working Download-Link for this free plugin.
Is there an other way?
Alan Lorence
Re: Searching a way for importing position data from voodoo or icarus ...
on May 22, 2008 at 1:03:36 pm
When you export the Voodoo tracking data as "text file", what information does it provide? If you can modify the data (using a spreadsheet program perhaps) so you only have the following info on each line:
frame_number x_pos y_pos
Then you can import that into particleIllusion (from text file).
I'd check out Voodoo now and see what data is added to the file, but I have too much to do right now already.
Alan.
http://www.wondertouch.com
Dennis Fassbaender
on May 22, 2008 at 6:32:23 pm
Thanks for that c4d-pi-exporter!
It works VERY FINE!
Greets,
Dennis
