How you use 16:9 ???
COW Forums : Boris FX Particle Illusion
Dennis Fassbaender
on May 12, 2008 at 2:20:26 pm
Anybody knows how to work with 16:9 PAL -DV Video?
By opening i have the 4:3 resulution...
Can´t find help anywhere :(
Ra-ey Saleh
Re: How you use 16:9 ???
on May 13, 2008 at 1:20:52 am
pI works in square pixels only, so you need to set up your project with the right aspect ratio first.
Press ALT+P for the Project dialog box.
Change your Frame Rate to 25.
Change your Stage Size to 1024 x 576.
Dennis Fassbaender
on May 13, 2008 at 3:44:24 pm
I know the resolution of 1024x576.
But when i import my video file its just 720x576 and doesn´t fit my stage size.
Si i can´t use any effects, because they don´t match my 16:9 footage (or i have to stretch them) ...
Alan Lorence
on May 13, 2008 at 7:49:04 pm
I think you need to resize your video to the "square pixel equivalent" size, then bring that resized video into particleIllusion, add your effects, then comp on the original footage.
Alan.
http://www.wondertouch.com
