Adding a text file to PI - from Truespace2PI
COW Forums : Particle Illusion
David Del
on May 7, 2008 at 6:51:48 pm
I have a TEXT file from the exporter - Position exporter to PI...so how do I import the text file (position data) into PI? After this is done, how do I take that info back into my 3d program?
Alan Lorence
Re: Adding a text file to PI - from Truespace2PI
on May 7, 2008 at 9:06:48 pm
R-click on the emitter in the hierarchy (after adding to the stage) and "import - position data".
There's no export back to 3D -- you render the particles with an alpha channel for compositing back on your 3D render.
Alan.
http://www.wondertouch.com
David Del
on May 7, 2008 at 9:24:35 pm
Ok, I guess that is not going to work in the way I had it set up presently.
Alan, I have a 3D camera running around a scene (3D space), but the place where I want the PI to composite is not moving (the camera is moving). When I export the data, it is the same number for each of the 400 frames because only the camera moves...so I am not sure how to proceed from here. Any suggestions?
