Crash on export to QuickTime
COW Forums : Boris FX Particle Illusion
Grete Hjorth-Johansen
on Apr 16, 2008 at 10:14:10 am
I am a using ParticleIllusion 2.0.1 SE, and when i try to output a QT movie the application crashes! Help!! I'm on MacBook Pro using QuickTime 7.0.4. It's a fairly old version of QT, is that the reason? I can't upgrade QT yet due to incompatibility with other apps. ParticleIllusion works fine otherwise, and used to work before with QT, but I haven't used it for a while and really need it for something now :-(
Any advice would be greatly appreciated!
Alan Lorence
Re: Crash on export to QuickTime
on Apr 16, 2008 at 12:29:46 pm
If it crashes with every compressor you try, and with all stage sizes (even 320x240 as a test), then I suggest a couple of things:
1) render a PNG image sequence instead of a QT movie
2) email support at wondertouch dot com with your problem and I'll send you the beta version of 2.0.2 to see if that helps.
Alan.
http://www.wondertouch.com
