No PAL DV AVI output
COW Forums : Particle Illusion
Dean Murray
on Apr 4, 2008 at 5:39:11 pm
Hi there,
I've just recently purchased the great Particle Illusion 3 and have found a problem with exporting as PAL DV.
The stage is set as 720 x 576 and I change the DV codec output settings to PAL DV, but the resulting AVI files are always 720 x 480.
Is the a known issue? and are there any workarounds except the exporting as uncompressed or PNG sequences etc.?
Thanks in advance,
Dean
Alan Lorence
Re: No PAL DV AVI output
on Apr 4, 2008 at 8:54:32 pm
It's the codec that's setting it to that size -- is there a setting in the codec (use the "configure" button in the codec chooser dialog) that controls that?
If you can let me know where I can get that codec I can take a look, because other people are having this happen too.
Alan.
http://www.wondertouch.com
Dean Murray
on Apr 7, 2008 at 10:02:06 am
Hi Alan,
I'd already found the PAL setting in the CODEC when I posted, unfortunately it was nothing as simple as that!
I had assumed that this CODEC came with Particle Illusion as I don't recall having the option from other applications before, but checking on another PC that doesn't have PI3 installed I still get the DV Video output option from other programs, which incidentally doesn't even output due to a different error!
It's not easy to see which DV CODEC is being used, as the About option does not display any information, but I suspect this may be the Windows Default DV CODEC (QDV.dll) and this is kind of also confirmed by GSpot.
Dean
Alan Lorence
on Apr 7, 2008 at 12:51:12 pm
particleIllusion doesn't install any codecs.
[Dean Murray] "It's not easy to see which DV CODEC is being used"
If you have more than one DV codec, they should all show up in the codec list in particleIllusion -- I'm not sure what you mean.
Alan.
Dean Murray
on Apr 8, 2008 at 8:33:09 am
Hi Alan,
I'm using Particle Illusion on Windows XP Pro and the CODEC I'm trying to export PAL DV from is called "DV Video Encoder".
Dean
MICHAEL CALLAGHAN
on Nov 28, 2008 at 7:37:00 pm
Hi Dean, did you ever find a workaround for this problem as i have encountered exactly the same issue using Particle Illusion SE free trial. Each time i output to pal using DV Video Encoder and import into Adobe Prem Pro the image is 720/480. I am impressed with the effects etc but would need to resolve this issue before purchasing.
Any help would be appreciated
Thanks, Michael
MICHAEL CALLAGHAN
on Nov 28, 2008 at 7:39:43 pm
Thanks, Michael
