Need help with Logo emitter
COW Forums : Boris FX Particle Illusion
Darrin Altman
on Apr 1, 2008 at 2:22:02 am
I just purchased particle illusion and have been studying for a little over an hour and started with the tutorials.
I am stuck on one thing I am trying to do. I changed one of the text emitters to be my logo. In particular the Logo Converge Sides. I have it working fine except I would like to extend the last part and cant figure out how.
For example the logo starts out extended and blurred and merges to center and then only stays fully visible for a split second. How do I make it stay solid a few more seconds before it fades to black?
Thank you for your help!
Darrin
Alan Lorence
Re: Need help with Logo emitter
on Apr 2, 2008 at 4:43:32 pm
This actually gets asked quite a bit. The easiest way is to use a separate emitter at the end. This emitter is a "single" particle with the text you want.
(like the cartoon "Mouse" emitter, but you use your text image instead).
I think somebody gave a more detailed explanation of how to do that in the forums here... so search the forums for "hold text" or something like that.
Alan.
http://www.wondertouch.com
