Non-Intensa Alpha PNGs in Photoshop.
COW Forums : Particle Illusion
Filip Stamate
on Mar 26, 2008 at 7:00:51 pm
Greetings.
I have encountered a problem when working with PI3 and Photoshop. If I save PNGs with non-intense alpha activated they will show completely blank in Photoshop, although in ACDSee for example they show quite nice.
I'm almost sure it must be something I need to change in Photoshop, but I have no idea what.
Thanks for your time,
Filip.
Alan Lorence
Re: Non-Intensa Alpha PNGs in Photoshop.
on Mar 26, 2008 at 10:08:17 pm
If you take a look at the docs on this topic, you'll see that "intense" particles are not included in the alpha channel when you check "create non-intense alpha" (CNIA), and you need to use a special blending mode when compositing.
So you probably don't need to use CNIA.
Alan.
http://www.wondertouch.com
