Importing Video to PI
COW Forums : Boris FX Particle Illusion
Roy Imbert
on Mar 7, 2008 at 10:20:35 pm
My name is Roy and i am new to PI. I just need to know how to import a video into PI. I've tried click and drag and a message comes up that reads "Not a Valid Particle Illusion Project. I could really use the help.
Alan Lorence
Re: Importing Video to PI
on Mar 7, 2008 at 10:58:01 pm
http://www.wondertouch.com/default.asp?loadContent=quickstart.asp
Take a look at the layers window (upper left window) in the first image.
Alan.
Roy Imbert
on Mar 9, 2008 at 7:04:23 am
Thanks Alan. Now can you help me make a specific trail for a meteor to follow. Please and thank you.
Roy
Alan Lorence
on Mar 10, 2008 at 1:47:01 pm
You can just click and drag the emitter to create position keys at different frames, or r-click on the emitter and "record position".
Alan.
Roy Imbert
on Mar 11, 2008 at 12:58:57 am
I've Tried that. But would it help if i told you that i use PI-SE? And i dount see that.
Alan Lorence
on Mar 11, 2008 at 1:29:13 pm
Don't see what?
R-click on the emitter in the stage window and select "record position".
Alan.
Roy Imbert
on Mar 13, 2008 at 2:47:56 am
Every Time I try that all it does is create another emmitter. Sorry if you think i'm wasting your time.
Alan Lorence
on Mar 13, 2008 at 12:42:18 pm
Have you looked at all 4 of the Quick Start images?
Have you looked in the html docs for "moving an emitter" -- it's pretty close to the start of tutorial 1.
The answer is you're in "Add" mode, which adds an emitter whenever you click on the stage. Use the toolbar button to toggle between "Add" and "Select" modes.
If you still are having problems, please post as much details on what you're doing so I can tell you where you're going wrong.
Alan.
