PI Alpha Channel issues
COW Forums : Particle Illusion
Randall Lee
on Feb 24, 2008 at 5:48:21 pm
Like Steve O'Hearn, I just purchased Particle Illusions and can't output with an alpha channel. I edit with Canopus 3.5 and I get the same results with Canopus lossless as well. I've down-loaded both Lagarith and Huffy UV from a couple of sites but none have the install icon (eg., right-click Lagarith.inf. Any advice would be greatly appreciated.
Randy Lee
RK Studios
randy@rkstudiosllc.com
Alan Lorence
Re: PI Alpha Channel issues
on Feb 25, 2008 at 1:51:34 pm
[Randall Lee] "I edit with Canopus 3.5 and I get the same results with Canopus lossless as well"
I'm not sure what you mean. "Same results?"
The Lagarith download at this site has an .inf file in the ZIP:
http://lags.leetcode.net/codec.html
Alan.
http://www.wondertouch.com
Randall Lee
on Feb 25, 2008 at 5:50:07 pm
By "same results" with Canopus lossless, I meant the Alpha Channel Option in the output options is not enabled. I did download Lagarith and the alpha channel option is enabled. However, when attempting to open the rendered file for editing in Canopus, I'm unable to do so. This may be an issue for Canopus to deal with now, though any suggestions would be appreciated. Thanks for your help.
Randall Lee
RK Studios
Alan Lorence
on Feb 25, 2008 at 7:21:50 pm
Ah -- we only enable alpha channel output for AVI codecs that are on an internal list. We'll have to add the Canopus lossless to that list in the next update.
Anybody else have any codecs that they know supports alpha channel, but particleIllusion doesn't enable the "save alpha" option for?
Alan.
Randall Lee
Canopus codec
on Feb 25, 2008 at 10:24:38 pm
Appreciate the honest answer and quick response. Obviously, looking forward to the next update.
Randall Lee
RK Studios
