BG Image disappearance...
COW Forums : Particle Illusion
Ra-ey Saleh
on Feb 8, 2008 at 12:34:07 am
Guys,
Can't work out what I'm doing wrong.
Essentially, all I want to do is import a BG image with alpha (which I see clearly on my stage) then export it and still see it.
Tried every possible way, but when I import the AVI into my Avid, the BG image with Alpha is no longer there. A BG image without an alpha works fine.
Alan Lorence
Re: BG Image disappearance...
on Feb 8, 2008 at 1:09:49 am
If you're saving alpha in the output, the alpha channel is created for the particles only -- the alpha of any bg footage is discarded.
So you'll need to add that bg footage back at the compositing stage.
Alan.
http://www.wondertouch.com
Ra-ey Saleh
on Feb 8, 2008 at 1:14:40 am
Thanks Alan, saved me going insane.
