Error Opening Library: Default.il3
COW Forums : Boris FX Particle Illusion
Brad Staupp
on Jan 15, 2008 at 7:41:07 pm
After Installing Particle Illusion 3 I am getting an Error Opening Library: Default.il3 when I try to run it. I have uninstaller, re-installed and re-activated with the same results. How can I solve this problem?
Brad
Alan Lorence
Re: Error Opening Library: Default.il3
on Jan 15, 2008 at 8:54:30 pm
It's telling you that it can't find the file -- just browse to the folder where particleIllusion is installed, then the "Emitter Libraries" folder, then select any library file there.
Alan.
http://www.wondertouch.com
