Is this a syrup pouring emitter?
COW Forums : Boris FX Particle Illusion
David Del
on Dec 26, 2007 at 12:15:26 am
I am looking for a emitter that looks like the slow pour of syrup on pancakes. . Thanks
Elvis Deane
Re: Is this a syrup pouring emitter?
on Dec 27, 2007 at 12:40:25 am
You can try the mud dropping emitter in the November 2004 library. Reduce the Visibility a bit and decrease the Weight and you might get something that looks pretty good.
David Del
on Dec 27, 2007 at 1:16:08 am
Excellent, I will try that out.
David Del
on Dec 27, 2007 at 2:01:14 am
Well, I tried. It still looks like poop/mud dropping - it doesn't have that smoothness to it, so I will have to keep looking unless you can think of another emitter...
Alan Lorence
on Dec 27, 2007 at 2:06:53 pm
I think you'll need to use one of the "lava" type emitters. The only way to get the smoothness is to make the particles blend together, and the way to do that is with "intense" particles. But the end result may need quite a bit of post work to get it looking syrupy.
Only other option is to use a fluid simulation application.
Alan.
http://www.wondertouch.com
