Scale Project Question
COW Forums : Particle Illusion
Miss Tapya
on Dec 7, 2007 at 6:59:39 pm
Hello to all:
The new feature of PIllusion 3.0.2
scale project
can anyone please help me
with any guidelines
what values I should
put if I want my
project to render in
a good resolution output
for video.
I want to use my project for some
dvd menus but kept making it so
low resolution...I want it crisp and clear..
thanks
Alan Lorence
Re: Scale Project Question
on Dec 7, 2007 at 9:26:50 pm
For DVD you want to use 720 x 480 (I believe) and set this in the Project Settings dialog.
When saving output, if you really want to save an AVI, use a lossless codec like Huffy UV or Lagarith for perfect (lossless) quality. Or save as a TGA or PNG image sequence.
I believe what you're describing is compression problems in the output, not the output resolution.
Alan.
http://www.wondertouch.com
Miss Tapya
on Dec 8, 2007 at 4:00:44 am
Thank You Alan...
yes you are right....
compression problems in the output.
erik gertscher
on Dec 10, 2007 at 10:31:48 am
I also have a question about the new feature, it looks to me that the emitters are not scaled to the new outzput size i choose. is there a way i can scale them automatically?
Alan Lorence
on Dec 10, 2007 at 1:13:05 pm
They ARE scaled (otherwise what's the point of this feature). If you have an example that appears not to work correctly, please send it to me IMMEDIATELY, as we're about to release the 3.0.3 update.
support at wondertouch dot com
Alan.
erik gertscher
on Dec 14, 2007 at 1:33:14 pm
hi alan
sorry i didn
Alan Lorence
on Dec 14, 2007 at 1:43:37 pm
You have to scale up to 1920 x 1440 (or whatever), then use the Project Settings to decrease the height (crops off the top and bottom). Or scale up to ____ x 1080, then use Project Settings to increase the width to 1920 (adds to the sides).
Alan.
erik gertscher
on Dec 14, 2007 at 3:23:42 pm
thank you alan
for your allways great and fast support
