avi
COW Forums : Boris FX Particle Illusion
celmar
avi
on Nov 29, 2007 at 10:15:49 am
I use mostly, doing animations in 3d, the following format: 720 by 576 pixels, witha pixel ratio of 1,067; which is the PAL format... I have sometimes (well, quite often) a problem, uploading the AVI in Particle illusion; I can see the thumbnail, when clicking on the little window, but the film don't "come", and the screen stay black... any hints?? thank you!!!
Elvis Deane
Re: avi
on Nov 30, 2007 at 6:35:52 am
Are you using version 3.02? That sounds like you may have the problem some people had in 3.01 with uncompressed AVIs, which should've been fixed by 3.02.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
Alan Lorence
Re: avi
on Nov 30, 2007 at 5:23:04 pm
After loading an uncompressed AVI in 3.0.2, if you see nothing in the stage window, check the "T" icon in the layer window. It's probably "on" -- click it to toggle it off (red X through it).
The uncompressed AVI you're loading has an alpha channel that is fully transparent.
Alan.
http://www.wondertouch.com
