how to change emitters frame rates
COW Forums : Particle Illusion
boranes
on Nov 17, 2007 at 9:07:57 pm
hi new to the forums.. how do i change the frame rates for the emmiters? is it possiable?
Aharon Rabinowitz
Re: how to change emitters frame rates
on Nov 18, 2007 at 2:34:15 am
you can change the frame rate for the project, by choosing View > Project settings and changing it there.
You can;t change the frame rate of an emitter though. Unless you mean changing the speed of the changing image in an emitter that uses an image sequence.
In that case use the slider found in the emitter properties next to the picture of the particle Shape image (in the particles Tab).
Aharon Rabinowitz
Email: arabinowitz (AT) yahoo (DOT) com
All Bets Are Off Productions, Inc.
Creative Cow After Effect Podcast
Internet Killed the Video Star: A Guide to Creating Video for the Web
boranes
on Nov 18, 2007 at 2:57:56 pm
thanks. im sorry i should of explained myself more!
but that should do it. im trying to slow down a emitter
its a eletrical disharge..i just wanted to have the bolts last longer...hmm ill post a video of what im talking about..
thanks so much for your help!
