how do i move the position of an item?
COW Forums : Particle Illusion
fall4mui
on Nov 9, 2007 at 3:23:33 am
as stated above, lets say i wanted to move an image from the top right to the bottom left, can i? and how? sorry if this is a beginner question
thanks
Sockratease
Re: how do i move the position of an item?
on Nov 9, 2007 at 5:08:42 pm
I would just make the image a particle (checking the "single particle" option) and treat it as any other emitter. Move it at will along the timeline.
You may be able to use layer offset too... I need to experiment with that feature more!
Maybe someone else has a better answer, but that should work.
MOO!
