How make the text remain after the emitter effect
COW Forums : Particle Illusion
Babykoh
on Nov 8, 2007 at 10:04:00 am
How to make the text remain through out after the text emitter effect. How to make lighting effect for text (something like those use in movies)
Sockratease
Re: How make the text remain after the emitter effect
on Nov 9, 2007 at 5:14:12 pm
Not sure on lighting effects in Particle Illusion, but you could make the logo a single particle emitter and have it begin where the animated one ends. That should provide a smooth transition.
If it fits your project, it could also be set as a background image which does not appear until the appropriate time, but that may not work in all cases.
Hope that helps.
Good luck with it
Peace.
