Change Random seed?
COW Forums : Particle Illusion
Change Random seed?
on Nov 6, 2007 at 4:15:33 am
Didn't there used to be a place where you can put in a new random seed number, to re-randomize the particles? Is that no longer possible w/ PI 3.02?
Is there a way to re-randomize your emitters? Say, if you wanted to produce several variants of the same animation?
Thanks, -px
Alan Lorence
Re: Change Random seed?
on Nov 6, 2007 at 11:36:14 am
You can't access the seed value right now (and have not been able to in the past). The seed value is randomized when the emitter is added from the library.
So if the emitter has been modified at all from its library version, you'll have to add it to a library temporarily (or a junk library), then use the "replace" function. Actually, I just tried this and it does not work -- the emitter retains it's seed value.
Only thing I can suggest is to tweak some values (number, velocity, or something else) to get the particles to "readjust". If the emitter uses a non-zero preload value, changing that will work too.
© 2018 All Rights Reserved
