Crash when rendering in avi format
COW Forums : Particle Illusion
Bryan Steagall
on Nov 4, 2007 at 1:42:50 am
Alan:
I'm having this issue consistently after upgrading to 3.0.2, when rendering to avi, the application stops and exits out.
This is what I've tried so far: Unchecked and checked "don't use texture ram for bg images", I've also tried unchecking hardware acceleration. All give me the same result.
I have no problems rendering to .jpg files (which is better anyway) but occasionally I do have a need to render in avi
Any information you might need, let me know so I can get it to you..
Bryan Steagall
Alan Lorence
Re: Crash when rendering in avi format
on Nov 5, 2007 at 11:08:54 am
At what point does it crash? Do you get the codec-chooser dialog? If so, what codec are you choosing? (Try a different codec and see if it still crashes)
And please email wondertouch support so I can add you to the 3.0.3 beta test.
Alan.
http://www.wondertouch.com
bryan steagall
on Nov 5, 2007 at 12:12:18 pm
Alan,
It crashes right after you select where to save the file and what format. If you choose avi or don't choose anything (leaving it at "all supported formats") , it hangs for a bit, then gives you:
particleIllusion has encountered a problem and needs to close. We are sorry for the inconvenience.
Only does this on avi (at least for me) I can still render in other formats..
Thanks for the help!
Bryan
