PI to AE
COW Forums : Boris FX Particle Illusion
powerbook
PI to AE
on Oct 23, 2007 at 7:30:47 pm
hi..i just got PI..so i'm still a bit confused.. how do I export from PI to AE with alpha?.. cuz when i tried to export the movie.. AE told me it doesn't have alpha.. and i can't find it on the manual.. for example i created the meadow in PI and export it as quicktime to AE..but in AE the black bg won't go away.. tried tweaking the layer but it didnt work..
i tried to export it as TIFF sequence with alpha on.. but the actual meadow was not included.. so what do i do?.. thanks in advance..
Elvis Deane
Re: PI to AE
on Oct 23, 2007 at 8:36:34 pm
If you render it as a Quicktime with compression set to None, and change Color Depth to "Millions of Colors+", you should be able to save a Quicktime with alpha.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
Alan Lorence
Re: PI to AE
on Oct 23, 2007 at 8:45:17 pm
Or use "Animation" compressor.
Then make sure you check the "Save Alpha" option in the Output Options dialog.
Alan.
http://www.wondertouch.com
powerbook
Re: PI to AE
on Oct 23, 2007 at 10:57:21 pm
right..it worked.. haha..thanks guys.. thanks a lot..
