clip sometimes freezes in SE
COW Forums : Boris FX Particle Illusion
buford
on Oct 23, 2007 at 2:11:49 am
Hello,
I hope this is a simple question. When I import a clip into the background (have SE), it will go along fine and then suddenly freeze. Why does it do that? I hope someone here can help me. Thanks in advance for any help. btw, I have a Mac, plenty of disk space.
Alan Lorence
Re: clip sometimes freezes in SE
on Oct 23, 2007 at 11:44:47 am
So you add the clip to a new project (that contains no emitters), then "play", and it freezes at some point? Does it require you to force-quit particleIllusion? How long is the clip?
Test with NO emitters in the project.
Alan.
http://www.wondertouch.com
buford
on Oct 23, 2007 at 11:39:17 pm
Hello Alan,
thanks for writing back! I'm such a newbie that I don't know how to turn off the emitters. My clips are only 20 to 30 seconds long. I also don't usually push play but rather use the guideline tab at the bottom and move it to where I would like to start adding effects (is that bad?). I don't need to force-quit the program. In fact, I can still add effects although the background clip is frozen. It seems to stop/freeze at around 300 to 400 frames(?). Is this the "stage width" in preference?
Also...sometimes it plays in real time and other in slow motion - why?
How do you turn off the emitters? Also, in preferences...is it better to work in "general" or "openGL".
Is there a glossary I can get my hands on? LOL
Again, thanks for helping!
Buford
