My library doesn't work anymore
COW Forums : Particle Illusion
on Oct 17, 2007 at 8:07:48 pm
Hi. First time poster here.
I use PI3 for about two years and I've developed... well, changed several effects to own versions, like changing the water emitter to a Phaser beam.
When I now try to open the library it says "Error: Access violation at 0x00421F88 (tried to read from 0x3858B068), program terminated"
Any way to repair the library? There's two years worth of work in there...
Thank you.
Re: My library doesn't work anymore
on Oct 17, 2007 at 9:19:16 pm
there may be a copy in the "library_backups" folder in your application folder.
Did you try and edit the lib or did it just go bad?
on Oct 17, 2007 at 11:22:29 pm
To my shame I gotta admit, it's become my Default Library (not by name, default does still exist) which I'm editing almost every two days...
I think I might have two emitters with the same name in the same folder, plus I ended Particle Illusion with a picture in it.
I also tried to dl 3.0.1 and 3.0.2... but 3.0.2 says my PI3 folder doesn't have the .exe in it... but I can see it...
Is there a possibility to upload the library to, say, rapidshare and one of you guys takes a look at it?
But I'm gonna try the backup first...
on Oct 18, 2007 at 1:29:39 pm
For possible future situations like this, some stuff I do...
--- I always make backups of my emitters every time I change something in them. I have a shortcut in my main emmitter folder to the backup location and just drag the most recently tweaked one into it.
--- I make and name my own "best of" collections by type keeping the originals in their own folder. That way, I can always go back and rix things do one degree or another.
Last but not least:
--- Projects are really the best place to edit and fine tune emitters: far more manageable with multiple viewable undos. Then if a real winner I want to archive, I can save it in and/or as a library.
I hope your situation works out.
Is there a library editor?
on Oct 20, 2007 at 1:23:00 am
I mean, outsides Particle Illusion.
I could open the library and delete misnamed emitters or at least try to do so...
Thanks in advance
Alan Lorence
Re: Is there a library editor?
on Oct 23, 2007 at 11:54:32 am
No, there is not.
But even if such an editor existed, it probably would not be able to load a corrupted library file.
If you zip and upload the corrupted file somewhere, I will take a look at it and see what the problem is. It may be fixable.
© 2018 All Rights Reserved
