No Image is shown in the particleView
COW Forums : Particle Illusion
OliverSchramm
on Oct 17, 2007 at 6:24:25 pm
Hi @ all,
first thanks to Alan and all the others for the great update of my most favourite software !!!
Only one problem:
In the new particleView i can
jholste
Re: No Image is shown in the particleView
on Oct 17, 2007 at 9:26:01 pm
Oli,
there is supposed to be a file "image.raw" in the application folder. I am quite sure it was not in the install, update or full. We will have to hope Alan will bail us out and provide a link.
John
Alan Lorence
on Oct 17, 2007 at 9:34:27 pm
Here is the link. Unzip into your pI3 folder (where the particleView.exe is).
http://www.wondertouch.com/downloads/pview_image.zip
Alan.
razors
on Oct 19, 2007 at 3:18:53 am
Weird. Unzipped file into pI folder and still no image appears.
OliverSchramm
on Oct 19, 2007 at 5:14:59 am
Hello,
i can confirm this. Still no image.
Regards,
Oli
Alan Lorence
on Oct 19, 2007 at 11:16:29 am
Depends how you launch particleView. If you browse to the particleIllusion 3 folder and double-click the pView exe there, the image display will work. If you use a desktop shortcut (or Start menu, or Quicklaunch) it won't.
The reason is we didn't fill in the "Start in:" property of the shortcuts.
To fix this, r-click on the shortcut (whether it's on the desktop, in the Start menu, or in the quicklaunch bar) and select "Properties". Then change the "Start in" box to point to the folder where particleView.exe is located. You can copy and paste this from the "Target:" box above, but you have to remove the "particleView.exe" part.
So on my system, I have:
Target: "C:Program FilesparticleIllusion_3particleView.exe"
So I need to make "Start in" look like:
Start in: "C:Program FilesparticleIllusion_3"
Notice that the quotes are required if the path has any spaces in it. Also, there is no ending slash on the "Start in:" path.
Alan.
OliverSchramm
on Oct 20, 2007 at 2:44:24 pm
O.K.
Thanks Alan, now it works fine ;-)
Regards,
Oli
