3.02 update issue.
COW Forums : Particle Illusion
David
3.02 update issue.
on Oct 15, 2007 at 11:17:23 pm
Hello everyone.
After downloading and installing the new update, I am trying to load in a dv avi file to use.
What I get is this message,
"The framerate of this movie is 29.97, not 30.00... but will still be used"
then it asks to change the stage size. I say yes or no and it crashes the program.
Any clues what happened. I thought dv was exceptable with this update?
Thank you for the great service here guys!
I mean that!
David R
David
Re: 3.02 update issue.
on Oct 17, 2007 at 12:48:42 am
Any takers on this?
Did I miss something? Should I be rendering out my dv avi from Vegas to an uncompressed avi to use in PI?
David
jholste
on Oct 17, 2007 at 1:51:41 am
David,
Can you play the file with Windows Media Player? If not it is possible you don't have the codec required to decode the file.
John
David
on Oct 18, 2007 at 1:20:50 pm
Hello John.
This is a dv avi straight off the tape.
It plays in everything just fine.
I read the post below where the gentleman was rendering out of vegas as an uncompressed avi to PI. I tried this and it works. Is this the practice?
I thought you could just take a dv avi and drop in PI.
Confused.
DR
jholste
on Oct 18, 2007 at 2:56:19 pm
David,
Well you should be able to read any dv avi in pI if you have a codec that supports that format. It would appear you have a codec that supports that format because it plays in other programs.
If possible can find out what codec compressed the file?
So I guess if the work arround works use it but it isn't the way it is supposed to work.
John
David
on Oct 18, 2007 at 4:27:36 pm
It is brought out of a panasonic camera to a sony media converterbrings it in to Vegas Pro 8. I believe main concept is used to bring in through Vegas capture?
Not sure. Does Elvis use vegas?
I thought another her might as well.
Also I still have to ok through Vista that it is fine to run PI.
I am logged as the administartor as well but it still always asks. LOL
I thought Alan said this might go away after update install but so far nothin a go.
Thank you for your time John. I mean that. ; )
David
jholste
on Oct 18, 2007 at 6:07:07 pm
David,
Unfortunately that doesn't help me. Could you please open the file in Windows Media Player and do a file properties and it should show the Video codec.
Maybe Elvis or one of the other Vegas guys can help?
John
David
on Oct 18, 2007 at 7:38:43 pm
Hello John.
It states DV Video Decoder as the codec.
DR
Alan Lorence
on Oct 18, 2007 at 8:04:20 pm
Does the DV clip contain audio? If so, try importing the clip without audio, and see if that loads in 3.0.2.
Alan.
http://www.wondertouch.com
David
on Oct 18, 2007 at 8:16:40 pm
Hello Alan.
Nope still crashes PI.
Starts by first saying the size is 29.92 not 30 again. Than asks to resize stage, I say yes it crashes.
DR
David
on Oct 18, 2007 at 8:18:16 pm
sorry that s 29.97 fps
Alan Lorence
on Oct 18, 2007 at 8:25:00 pm
email me at support at wondertouch dot com and we'll figure this out. (and post what I find)
Alan.
David
on Oct 18, 2007 at 8:39:29 pm
You've got mail sir. : )
FeelTheLove
on Oct 19, 2007 at 12:26:02 am
Alan, Dave,
I have the same issue which I posted before. Any help would be appreciated. I am currently using my older version of PI without this issue. Thanks again...love the product
Alan Lorence
on Oct 19, 2007 at 11:04:29 am
We've found that if you have the Panasonic DV codec installed, 3.0.2 will crash when loading DV AVIs. So the answer (for now) is to remove the Panasonic DV codec either using a tool like Codec Sniper, or by using Windows to remove the codec.
Alan.
FeelTheLove
on Oct 19, 2007 at 12:36:46 pm
Thanks Alan, downloaded Codec Sniper...but not sure what the name of the panasonic codec is...do you? thanks for your help
Alan Lorence
on Oct 19, 2007 at 12:45:44 pm
It starts with "pdv" -- I think "pdvcodec.dll".
Alan.
FeelTheLove
on Oct 19, 2007 at 6:53:12 pm
Thanks Alan...that did the trick. Everything is working fine now.
