Sample Projects in 3.0.2
COW Forums : Particle Illusion
Alan Lorence
on Oct 12, 2007 at 8:42:40 pm
One thing that isn't mentioned anywhere, is that 3.0.2 installs some new sample projects which are in fact some of the projects used in our 2006 demo reel.
Unfortunately, the 3.0.2 updater does not include these new sample projects -- they're in the full installer (and demo version) only. But if you want these sample projects...
1) Download this file
2) unzip the files into the "Sample Projects" folder of your particleIllusion 3 folder (or put it in any folder, really)
3) When you load some of these projects, you'll get "missing image" messages. In most cases you want to click "yes" on the "find the images?" question, then just click "OK" -- the file dialog is probably already pointing to the right location.
The only exception to this is in the "lower 3rd" project -- I forgot to remove the "interview" footage from the project, so you may not be able to find that one. So when it asks about "interview", click "yes", but if it can't find the image (one image is there -- not the whole sequence) just cancel the dialog. When it asks about "fill.png" click "yes" (important!).
4) Save the project after the images have been found so you won't have to do this again.
There are some great example projects there. Thanks to Aharon and Elvis for putting some of them together.
Re: Sample Projects in 3.0.2
on Oct 12, 2007 at 9:54:02 pm
Got'em! Thank you.
© 2018 All Rights Reserved
