Pillusion render AVI option
COW Forums : Particle Illusion
Luddemannen
on Oct 12, 2007 at 1:02:13 pm
Hi, Thanks for the update, but when I click AVI options button in the render, windowsxp sais it has generated an error and need to close ?, what do I have to do ?
Alan Lorence
Re: Pillusion render AVI option
on Oct 12, 2007 at 1:08:30 pm
Can you be more specific? I'm not sure if you mean in the update (3.0.2), in pIllusion, in pIRender, etc.
Alan.
http://www.wondertouch.com
Luddemannen
on Oct 12, 2007 at 1:15:03 pm
Hi, i updated to 3.02, but then when I click the AVI option button in the standalone PillusionRender it sais it has generated an error and need to close, I have tried reset deafault settings to, but it is the same
Alan Lorence
on Oct 12, 2007 at 1:22:15 pm
Ok, thanks. Try this and see if it crashes too:
1) run particleIllusion 3.0.2
2) ctrl-click the Save Output button. (This will force pIRender to be used for the render)
3) choose an AVI as output
When pIRender launches, it should open the codec selection dialog right away. If that works, select any codec and click the "render" button so pIR does the render and closes.
Now try running pIR alone and clicking the AVI Options button.
Alan.
Luddemannen
on Oct 12, 2007 at 1:28:32 pm
No I did as you suggested, first the save as dialog comes up, I choosed to save it as an avi, then output options dialog comes up, and after that, the standalone render comes up, but it still sais it have generated an error and needs to close and want me to send the problem to microsoft
jholste
on Oct 12, 2007 at 1:36:36 pm
When you run pIllusionRender what is in the box to the left of the AVI Options button? Also is it possible for you to save to a WMV output and click the WMV Options button?
Luddemannen
on Oct 12, 2007 at 1:42:53 pm
To the left of the AVI option button in the field it sais "CineForm HD Encoder-2" I can
Alan Lorence
on Oct 12, 2007 at 2:17:19 pm
If you render an AVI with pIllusion 3.0.2, you don't have any problems, right?
Close pIRender.
If you're familiar with Regedit, please run it and look at the following key:
HKEY_CURRENT_USERSoftwarewondertouchpIllusionRenderSettingsAviCompressor
Edit it, and set its value to "0", then close Regedit.
If pIRender still crashes when you click the AVI Options button, delete the whole
HKEY_CURRENT_USERSoftwarewondertouchpIllusionRender key.
Let me know what works.
Alan.
Luddemannen
on Oct 12, 2007 at 2:46:50 pm
It works, :), but however seems to be the cineform encoder that makes the problem, Now I can choose avi codecs, but when I choose the cineform encoder it is the same, not much of a problem now, just have to see that I don
Alan Lorence
on Oct 12, 2007 at 3:04:25 pm
So what was the solution? What did you have to do exactly in order to make it stop crashing?
The pin connection error messages usually indicate that you're trying to render a resolution that the codec does not support. Some codecs only support specific sizes, while some codecs support any size.
Alan.
Luddemannen
on Oct 12, 2007 at 3:16:18 pm
The solution was as you suggested :
"If you're familiar with Regedit, please run it and look at the following key:
Edit it, and set its value to "0", then close Regedit"
The value showed "3", so I changed it as you suggested to "0"
restarted my computer and after that it worked perfectly, Thanks !
Alan Lorence
on Oct 12, 2007 at 3:22:17 pm
Ok, now the question is: If you run pIRender, click the AVI Options button, then select the 4th (not 3rd, 4th) codec in the list, click OK to close the dialog, then close pIRender and run it again, will it crash the next time you click the "AVI Options" button in pIRender?
(BTW, you didn't need to restart your computer)
Alan.
Luddemannen
on Oct 12, 2007 at 3:30:02 pm
The 4:th codec in the list is "CineForm HD Encoder-2", it crashes when I choose it, but then when I start it again, it choose ? probably the last that worked, in my case full frames uncompressed !!!
Alan Lorence
on Oct 12, 2007 at 3:47:07 pm
You may want to install a tool like "codec sniper" -- something that will list all of your codecs, tell you if they are "ok" or "broken", and let you remove bad codecs.
Just Google "codec sniper".
Also, don't use "full frames (uncompressed)" unless you really need to. I suggest either the "Lagarith" or "Huffy UV" codecs instead. They're lossless, both support alpha, and will give you MUCH smaller file sizes than uncompressed.
Alan.
Luddemannen
on Oct 12, 2007 at 6:33:48 pm
I downloaded the codec sniper, run it, said ok on all my installed codecs, usually I render out *.TGA:s, old habit, but anyway my computer seems to run uncompressed avi:s without any problem !!, but I will install "Lagarith" and "Huffy UV" codecs...
