Importing only 9 picture sequence
COW Forums : Particle Illusion
Digit0
on Oct 3, 2007 at 9:03:30 am
Hi All,
I changed the shape of particle and am trying to use sequence of 13 pictures with similar names eg pic1, pic2 etc. But it only imports 9 of the 13. I have put them in a seperate folder. Does it depend on the particle that I'm using?
Craig
Sockratease
Re: Importing only 9 picture sequence
on Oct 3, 2007 at 9:22:45 am
Try renaming the lot to "pic001" to "pic013" as sometimes the transition from "pic9" to "pic10" has translation problems!
At least in other software.
I have never had the problem you describe in Particle Illusion, but I have seen this in other sequence-importing software.
I'm no expert, nor am I the support staff, so I hope that helps.
Good luck with it.
Peace.
Alan Lorence
on Oct 3, 2007 at 11:14:37 am
That's exactly it. You need to add leading zeros to the sequence number, so all the images have the same number of digits.
Alan.
http://www.wondertouch.com
