ip3 conversion?
COW Forums : Particle Illusion
ip3 conversion?
on Sep 7, 2007 at 12:24:10 pm
How do you convert your particle illusion project into a mpeg or avi? I'm trying to put it on the web.
Re: ip3 conversion?
on Sep 7, 2007 at 8:58:09 pm
Hi Carlito3113
The Red Dot on the PI3 Toolbar (Save Output) allows you to save the frames in a number of formats. This is different to Save As that saves the PI3 project.
Depending on your needs (AVI or PNG sequences to keep Alpha/Transparency) are popular as you can then composit sequences in apps such as After Effects.
If you use AVI, you can use any Codec you have installed (such as DivX etc).
Saving for Web I guess you can use Flash to create a SWF or better still FLV.
(Just my personal prefs here)
Hope this helps!
Kind regards
Rod Davies (UK)
© 2018 All Rights Reserved
