PI-3: Best AVI Codec/Format for Background Image?
COW Forums : Particle Illusion
Soniclight
on Aug 31, 2007 at 9:37:33 am
I've read all the FAQ on AVI and know that there will be improvements for AVI export in due time.
I don't want to install the albeit free, potentially problematic Panasonic DV codec for I've had a long headache just getting my JVC SD camcorder's codecs to work :)
I also have Sony Vegas 6 at this point and rolled back my Windows Media Player to 10 for it's less bloated and more stable for me. Loading new codecs can be tricky and I want to avoid them unless absolutely necessary.
And, I may not need to anyway...
So far, I've been using uncompressed AVI xports from Vegas just to play it safe for PI, but it's impractical for two reasons:
--- Huge file = A) takes up HD space and B) must put strain on PI (as it would any app playing back a 1 or 2 Gb file).
At this point, I use these AVI to create or map effects that I then export to Vegas to composite on the AVI's original edit. Otherwise put, the AVI I use in PI is essentially a stand-in" file.
So...
--- What is the best recommended codec/format/compression (i.e. the one you guys use the most at PI headquarters) for such "stand-in" AVIs?
Thanks.
Elvis Deane
Re: PI-3: Best AVI Codec/Format for Background Image?
on Aug 31, 2007 at 2:25:31 pm
I find that frameserving from Vegas is the best way. No big file, no recompression. There's a description of how to do that here.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
Soniclight
on Aug 31, 2007 at 7:09:48 pm
Ah-haa, so that's what FrameSaver does! :) Thanks.
I had passed on FS back when I first got Vegas as I was scouring VASST and such for extra ditties. Definitely a space saving solution and more.
I'll have it intsalled by the time you read this reply.
Soniclight
on Aug 31, 2007 at 7:12:07 pm
Ah-haa, so that's what FrameServer does! :) Thanks.
Soniclight
on Aug 31, 2007 at 7:14:07 pm
Soniclight
on Aug 31, 2007 at 7:15:16 pm
I'll have it intstalled by the time you read this reply.
Soniclight
on Aug 31, 2007 at 7:17:12 pm
BOARD ADMIN: Sorry about the repeat posts, tried to go back and edit and it just accumulated, feel free to delete all but first one.
