Alpha Channels Problem, HELP!
COW Forums : Particle Illusion
cbcedit
on Jul 29, 2007 at 1:46:33 pm
Hi All,
I seem to be missing someting, I don't see an alpha channel when producing an effect using trail emmitters. Is this normal or could
I have a problem with my program or is their something special I'm missing.
Alan Lorence
Re: Alpha Channels Problem, HELP!
on Jul 30, 2007 at 11:41:02 am
You need to check the "Save Alpha" option in the output options dialog. This will only be enabled on Windows versions for TGA and PNG, and on Mac for the same and QuickTime movies if you have a compressor selected that supports alpha and set the number of colors to the highest.
Alan.
http://www.wondertouch.com
cbcedit
on Jul 30, 2007 at 4:07:57 pm
Thanks Alan,
Iwas aware of your point. However, when I put a trail emmitter
on the stage and select alt-A to view the alpha channel it
isn't viewable. Other emmitter do produce a alpha channel.
Do Trail Emitter produce an alpha channel or could I have a problem with my program.
Alan Lorence
on Jul 30, 2007 at 4:57:29 pm
You probably have "create non-intense alpha" (CNIA) turned on. Use "Alt-Shift-A" to toggle it. Easiest way to see this is to add an emitter (or two) that has some intense particles and some non-intense, view the alpha channel, then toggle CNIA.
Alan.
cbcedit
Re: THANKS FOR THE HELP
on Aug 1, 2007 at 1:00:25 pm
Thanks for the help, that was the fix to my problem.
Cheers!
