Regarding the LOOP TUTORIAL, short question
COW Forums : Boris FX Particle Illusion
lLOlBO
on Jul 26, 2007 at 8:44:07 pm
I will be very thankful if you could tell me how to RENDER into .PNG images as this tutorial describes>>> http://www.wondertouch.com/tutorials/PI%20Loop%20Tutorial%20V3/PI%20V3%20Lo...
I'm a bit lost with that part, because when i render i get only the possibility to do it on following formats > JPEG, CMP .... but no PNG?!...
Thanks in advance
Elvis Deane
Re: Regarding the LOOP TUTORIAL, short question
on Jul 27, 2007 at 1:58:06 am
Are you using version 3 of particleIllusion, or SE? SE has limited formats compared to 3.0, but you can save out TGA files with an alpha channel (might not show up in the drop down as I recall, but it does work if you just leave it at the default and type .tga after the filename).
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
lLOlBO
on Jul 27, 2007 at 1:03:32 pm
actually my version is 3.0.1
I have TGA, maybe after rendering in TGA frames, i will use a third party application to batch TGA into PNG so i get the results.
In any case it will be useful to know how to do this directly from PI.
here is the project im working with:
http://www.netherworld-ro2.com
Im trying to LOOP the HEADER effect and the ANGEL ANIMATION'S FIRE, to get a continuos animation (until now without success) .
Any advises on how to get this to work?
Best Regards
lLOlBO
lLOlBO
on Jul 28, 2007 at 1:42:25 pm
any clue or tip?
Alan Lorence
on Jul 28, 2007 at 2:16:46 pm
Just render to TGA. There's no reason you shouldn't be able to render PNG though.
Alan.
lLOlBO
on Jul 30, 2007 at 2:54:37 pm
well i dont get the option to save as PNG -.- thats the problem, and thats why i m asking for help. Is strange indeed as a friend of me has the option to do it...
Alan Lorence
on Jul 30, 2007 at 5:02:29 pm
So you're using particleIllusion 3.0, and there is no "PNG" option in the file types pulldown list when specifying the output filename? I don't know how that would be possible.
Email wondertouch support, although I'll say that you're probably not using a registered (legal) version of the software. I apologize if I'm wrong, but we've never received a "I can't save xxxxx image format" messages from a registered user.
But you've also missed the most important part of my previous message -- the part that says "just save as TGA".
Alan.
lLOlBO
on Jul 30, 2007 at 8:58:54 pm
well , actually the program is the same as the one from friend he installed it on both computers... we tested today again ... without success, so after i reinstall it from the ORIGINAL CD i will come back to you.
And i thank you for your attentions.
