batch render problem
COW Forums : Particle Illusion
erik gertscher
on Jul 26, 2007 at 12:17:28 pm
i am trying to render some pIllusion projects with the batch renderer.
the project settings are NTSC DV (Pixel Equivalent Size) FPS 29.97 Full Frames Uncompressed AVI
But the rendered files have a cinepak radius compression and a fps of 29.00
So please can you help me
Alan Lorence
Re: batch render problem
on Jul 26, 2007 at 12:36:49 pm
Open pIllusionRender itself and set the AVI settings to the codec you want to use, then do a "junk" render to make sure pIRender is using the settings.
Then close pIRender and now when pIRBatch calls it, it will use the AVI settings you want.
Not sure about framerate, but it's probably related to the codec. Or you're not using the latest pIRender?
© 2018 All Rights Reserved
