can't see all layers
COW Forums : Particle Illusion
stuartambient
on Jul 18, 2007 at 9:00:28 pm
I have two layers (layer 0 and layer 1). 1 emitter on one layer, another (different) emitter on second layer. Yet I can't see both emitters / layers at the same time.
Is there an option for turning on all layers or something ?
TIA
Stuart
Elvis Deane
Re: can't see all layers
on Jul 20, 2007 at 5:17:40 am
Check to make sure nothing is turned off in the Layers window. Unless you have the emitters or particles hidden on a layer (either by turning them off in the Layers window or by clicking the star icon beside the emitter's name in the Hierarchy window), everything on both layers should be visible.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
Alan Lorence
on Jul 20, 2007 at 11:49:45 am
Unless you mean that you want to see the emitter symbols and paths on all of the layers at the same time. If that's what you mean, then r-click (control-click on one-button Mac) in the Layers window and uncheck "current objects only".
Alan.
http://www.wondertouch.com
kirktab
on Oct 7, 2007 at 1:22:27 pm
... or your emitters might be placed on your stage at different frames - if the missing one appears when you scrub the time indicator, there's your problem...
