Buffy Dusting
COW Forums : Boris FX Particle Illusion
Enrico01
Buffy Dusting
on Jul 16, 2007 at 7:30:06 pm
Hi.
I'd like to reproduce the dusting effect on Buffy. I'm not that experienced with "particle Illusion". I can do the skeleton thing, etc. on After Effects, the problem is the dust. None of the effects in my libraries really look the same. Where can I get or how can I create such a dust particle?
PS: If you don't know what I'm talkin' about, I made a little video. My cut software acted weird, so it's not the way I wanted it, but you can still see what I mean.
http://rapidshare.com/files/43297252/010101.avi
Thanks in advance
cowcowcowcow
Elvis Deane
Re: Buffy Dusting
on Jul 17, 2007 at 3:20:46 am
The Dust Puff emitter from the March 2000 library is a good starting point. You'll probably want to increase the Velocity and drop the Size a bit.
If you click on my head at the top of the forum, there's a tutorial with a different approach to the disintegration effect that you might be able to pick up some ideas from.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
