Make invisible end of the effect
COW Forums : Particle Illusion
shinodas
on Jul 5, 2007 at 4:37:19 pm
PLEASE.How can i make invisible end of this EFFECT?
http://image004.mylivepage.com/chunk4/339308/246/Bez%20n%C3%A1zvu.JPG
Which part of the effect i want make invisible is in red area in that photo.
If u know help me, pls write on lumusolem@azet.sk
THANXXXXXXXXXXXXXXXXXXXX
4ever charmed
Elvis Deane
Re: Make invisible end of the effect
on Jul 5, 2007 at 6:32:04 pm
The first thing would be to make sure your emitter's Transparency Gradient fades out from white to black. And then if you need to, you can lower the Life down so that the fade out starts earlier. You may have to adjust your Over Life graphs slightly to make it all work.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
