Pixel size
COW Forums : Boris FX Particle Illusion
Paul Hansen
Pixel size
on Jul 2, 2007 at 4:51:51 pm
I have looked in the FAQs and haven't found the answer I need. Let's say I make a circle emitter and then save it as an AVI file. When I import it into Premiere, it is no longer a circle but rather an oval. Is there a way to correct this?
Elvis Deane
Re: Pixel size
on Jul 3, 2007 at 7:36:14 pm
Could be that the pixel aspect ratio of your Premiere project is set to 0.9 by default, and pI's stuff is square pixel. Don't have Premiere here to check that, but that'd be my guess.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
Paul Hansen
Re: Pixel size
on Jul 4, 2007 at 2:13:49 am
Thanks, Elvis. What SHOULD it be set to in Premiere?
Elvis Deane
Re: Pixel size
on Jul 4, 2007 at 8:10:58 am
It depends on your output. If you're going out to videotape/DVD, you'll want to keep it 0.9 since that will look oval as you work in Premiere, but should play right on a TV. If you're going out to the web, then a 1.0 pixel aspect ratio is a better bet.
Elvis Deane!
Paul Hansen
Re: Pixel size
on Jul 8, 2007 at 12:24:01 am
Is there a way to set the pixel size in PI to 0.9?
Elvis Deane
Re: Pixel size
on Jul 8, 2007 at 4:45:35 am
Nope, it's only square pixel at this point.
Elvis Deane!
dnavarrojr
Re: Pixel size
on Jul 22, 2007 at 11:52:14 am
One thing you might try is output to 640x480 from PI then "stretch" it to 720x480 to fit the full frame. This will distort your circle into an oval, but when viewed on TV it looks like a circle.
