Picture; bad quality
COW Forums : Particle Illusion
on Jun 27, 2007 at 7:34:59 am
I want to give some extra dimension to a photo, so I put some effects on it to make it nice (record position ---> trailer). I want to save this as a AVI-file in the "Save output". Everything goes right!
But....I want to use it in Magix, but when it's loaded in this program and I puse play, the photo is shaking a little bit, what gives a bad quality. What can I do about this?
Elvis Deane
Re: Picture; bad quality
on Jun 27, 2007 at 5:50:28 pm
What codec are you using to output to AVI? That's the only part of the process that should have an effect on the quality of the final image. Try this thread on some suggestions of codecs to try,
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
© 2018 All Rights Reserved
