Pixel Aspect Ratio
COW Forums : particle Illusion
LostCanuck
Pixel Aspect Ratio
on Jun 13, 2007 at 2:38:45 am
I'm working with Adobe Premiere Pro 2.0 and Particle Illusion 3.0. My job is to add effects to my already edited footage that was exported in Premiere.
I exported as the following:
File Type: Microsoft AVI
Frame Size: 720 x 480
Pixel Aspect Ratio: D1/DV NTSC Widescreen 16:9 (1.2)
As far as I know, PI 3.0 only accepts videos with a pixel aspect ratio of 0.9, therefore, the footage above becomes stretched vertically when imported. So my question is... Can PI 3.0 import videos with a pixel aspect ratio of 1.2 and also export with the same ratio of 1.2?
or...
Should I export my footage from Premiere with an aspect ratio of 0.9? And if so, what would the new frame size be? I don't want anything to stretch...
Please help.
Chris Schultz
Elvis Deane
Re: Pixel Aspect Ratio
on Jun 13, 2007 at 6:44:44 am
particleIllusion only reads things as having a 1.0 pixel aspect ratio, and that's the best way to bring footage into it. That would make 720x480 at 1.2 into a 864x480 size.
Elvis Deane!
The Apprentice Magician's Guide to particleIllusion
Wilbur of Wumbaberry
